Sheet Index Tables
I am using the Sheet Set options to creat my Sheet Index. It imports everything just fine. My issue is when I want to create a space between sections the option to add a row is greyed out. For ex I would like my sheet index to look similer to the following
S1.01
S1.11
S1.41
S2.01
S2.03
S3.01
ETC.
Is there a way to do this using the sheet index option in Sheet Set manager?
You can do this (sorta) by using 'subsets'.... ie: place S1 drawings under a subset, place the S2 drawings under another subset, etc. When you create the sheet list table, ensure you click the 'show subheader' checkbox (lower left corner). What I am assuming is that you can name your 'subsets' with spaces so no name shows up (or edit it manually afterwards).
This will work, course you could always just insert the table, explode it and manually edit it. Kind of a pain cause you won't be able to update table data links but it only takes a minute to remove and reinsert a new sheet list table.
Some options anyway, good luck.......
