Digidoug Posted July 29, 2011 Share Posted July 29, 2011 When I right click on a viewport I no longer get the menu that includes the lock/unlock choice, or anything else. I can select the viewport but I have no control over it. Also when I select objects the layer information is not displayed. Until today I did not have this problem. I'm thinking it might be a settings issue, because if I open this file up on another computer I can control viewport as usual. The only think I can think of that I may have done different is I was experimenting with rotation of view ports. I would greatly appreciate help. Quote Link to comment Share on other sites More sharing options...
tzframpton Posted July 30, 2011 Share Posted July 30, 2011 What does it say in the Properties palette when you click the Viewport? Can you lock/unlock it from there instead? Quote Link to comment Share on other sites More sharing options...
Digidoug Posted July 30, 2011 Author Share Posted July 30, 2011 The only way I know of activating the properties palette is by selecting the viewport boarder and then right clicking. I can select it but right clicking does nothing. Is there another way? Quote Link to comment Share on other sites More sharing options...
tzframpton Posted July 30, 2011 Share Posted July 30, 2011 Ctrl+1 opens the Properties palette. Quote Link to comment Share on other sites More sharing options...
nestly Posted July 30, 2011 Share Posted July 30, 2011 Someone or something changed your PICKFIRST value to 0. Change it to back to 1. Quote Link to comment Share on other sites More sharing options...
Digidoug Posted August 2, 2011 Author Share Posted August 2, 2011 Thanks so much. Changing PICKFIRST setting to 1 did the trick. As you can see I am a newbee, and without your help I would probably still be looking for the answer. Thanks Again! Quote Link to comment Share on other sites More sharing options...
nestly Posted August 2, 2011 Share Posted August 2, 2011 Glad you got things working again. Quote Link to comment Share on other sites More sharing options...
BlackBox Posted August 2, 2011 Share Posted August 2, 2011 Awww... Nestly, you're so sweet. Quote Link to comment Share on other sites More sharing options...
