Marc5 Posted August 1, 2011 Posted August 1, 2011 When I select Display Order / any of the selections under this command I get on the command line UNKNOWN COMMAND. Why? Thanks, Marc Quote
BlackBox Posted August 1, 2011 Posted August 1, 2011 It sounds like the AI_DRAWORDER application is not being loaded during startup. Post a copy of your command line output after a clean start. Be sure to include an example of attempting to manipulate the draw order as well. Quote
Marc5 Posted August 1, 2011 Author Posted August 1, 2011 This is what I get after display order: Command: Unknown command "AI_DRAWORDER". Press F1 for help. Command: Unknown command "FRONT". Press F1 for help. When I press F1 I get the following: INT Unknown command "INT". Press F1 for help. Quote
