I have donloaded ObjectARX from Autodesk site and i have autocad 2012 and visual studio 2010 please can u tell me how can i install this and het it in vs2010.
thanks
Open the ObjectARX ZIP file and double click the MSI file to install it. It will be automatically recognised by VS2010.
No it is not like when i am extracting and installing the file i get a message
There is a problem with this windows installer package a script required for this install to complete could not be run contact your support personal package vendor.
thanks
Do you have administrator rights when you try to install the package?
No actually i even tried to installed as a adminstrator but fail i have 64 bit operating windows 7 system can u tell is this the problem or another.
thanks
thanks
Try this kulfi.
go ahead to the main drive of your PC and go to properties and to Security Tab to get the allowance and after that you can
start with your ARX installation .
Good luck.
Tharwat
I have tried that also but the same problem.
Maybe right click on the installation folder then chose "run as administrator" would help in most cases . TRY IT .
