VB.Net - Edit dwg files without opening them
CaveMan
Good Day
looking for code in vb.net where i can retrieve what exrefs are in a drawing file without opening it. Will also like to be able to edit the exrefs paths and files within the drawing database.
The method would also be useful to extract attributes etc. from drawing files without opening them. Any help most welcome.
Regards
CaveMan
Have a look on Kean Walmsley's site Through the Interface and try a search there. Link: http://through-the-interface.typepad.com/
It is possible to access a drawing database without opening the drawing or having AutoCAD installed on the machine, but I'm not sure if you need software called RealDWG to doit, never tried it myself.
I have read through some of Kean Walmsley's tutorials before - quiet intense level at times - appreciate the link - at the moment have a sample - but have to step through it piece by piece - not sure if it will work though???
Guess if we do not try we cant make mistakes to learn from?
Regards
CaveMan
You need RealDWG if AutoCAD is not installed or if you do not want AutoCAD running.
For a better solution look at Database.GetHostDwgXrefGraph where you can get nested Xrefs
This is Hard-coded for a simple example and just to get you started
You have both Drawings in "C\Test"
XrefDrawing.dwg and XrefHost.dwg
XrefHost has XrefDrawing xref in and move it to another folder
--Database.ReadDwgFile for opening a drawing where you do not interact with it in the Editor
--Iterate the BlockTable checking the BlockTableRecord.IsFromExternalReference Property
--Change PathName property and move file
       <CommandMethod("ChangeXrefPath")> _
       Public Sub ChangeXrefPath()
           Using db As New Database(False, True)
               Try
                   db.ReadDwgFile("C:\Test\XrefHost.dwg", FileOpenMode.OpenForReadAndWriteNoShare, True, Nothing)
                   Using trx As Transaction = db.TransactionManager.StartTransaction()
                       Dim bt As BlockTable = trx.GetObject(db.BlockTableId, OpenMode.ForRead)
                       For Each objId As ObjectId In bt
                           Dim btr As BlockTableRecord = trx.GetObject(objId, OpenMode.ForRead)
                           If btr.IsFromExternalReference Then
                               btr.UpgradeOpen()
                               btr.PathName = "C:\Test\NewLocation\XrefDrawing.dwg"
                               Exit For
                           End If
                       Next
                       trx.Commit()
                   End Using
                   db.SaveAs(db.Filename, True, DwgVersion.Current, db.SecurityParameters)
               Catch
               End Try
           End Using
           System.IO.File.Move("C:\Test\XrefDrawing.dwg", "C:\Test\NewLocation\XrefDrawing.dwg")
       End Sub
   End Class
Edited by Jeff H
Interesting thread.
@ Jeff - "ChangeXrefPath" has a lot of new stuff (for me) in there, which has helped to answer *how* to re-write some of my LISP code in VB.NET (hooray!).
Cheers! :beer:
