SCaldeira Posted August 2, 2011 Share Posted August 2, 2011 Greetings. I wonder what the best way to select the elements of a layer whose name I know at first, and change your view (not the layer) including the type of line, its thickness, color and even the text type and height . Thank you. Quote Link to comment Share on other sites More sharing options...
rkmcswain Posted August 2, 2011 Share Posted August 2, 2011 Can you be more specific? I wonder what the best way to select the elements of a layer whose name I know at first Just reading that part, I would say.... Layer Isolate, then select. -or- Filter or Qselect command ...but the second part of your question is unclear. Quote Link to comment Share on other sites More sharing options...
ReMark Posted August 2, 2011 Share Posted August 2, 2011 By "view" might you mean "Properties"? Quote Link to comment Share on other sites More sharing options...
Tharwat Posted August 2, 2011 Share Posted August 2, 2011 By "view" might you mean "Properties"? Or maybe the presentation of objects . Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted August 2, 2011 Share Posted August 2, 2011 Since this is posted in the programming forum, I'm guessing that you want to do this as part of a LISP program. In which case, ssget is the function you will need to study. Consider this example to create a selection set of all entities on the layer Layer1: (ssget "_X" '((8 . "Layer1"))) You will need to clarify your other intentions however. Quote Link to comment Share on other sites More sharing options...
SLW210 Posted August 2, 2011 Share Posted August 2, 2011 SCaldeira, Perhaps you should try a different translator. What you are asking is unclear. Quote Link to comment Share on other sites More sharing options...
