TonyBorland
bend
TonyBorland
I`m not able to add a .3mm fillet to a part containing Bends.What do i need to change so as to get the fillet to work on the entire modelbend.ipt?.Model made with Inventor 2012.
Cheers
TBorland
Edited by TonyBorland
Share this post
Link to post
JD Mather
I would start by reading this document. http://home.pct.edu/~jmather/skillsusa%20university.pdf
I noticed that your first sketch isn't constrained - even though you placed at origin. This should be automatic.
It was also unclear to me where you were trying to add the fillet - I am able to fillet the entire part?
(pull down EOP in attached file)
bend.zip
Share this post
Link to post
TonyBorland
Cheers...i was using Loop select
Would this part be better made with sheetmetal?
It was the 1st time i use the bend command....does the bend feature always leave segments where the part is bent?
Tony B
Share this post
Link to post
JD Mather
I would have modeled as-folded to the finished dimensions, probably as a trimmed surface and then Thicken.
It could also be modeled from sheet metal.
I would have used either of these techniques rather than the Bend as you did.
Share this post
Link to post
TonyBorland
OK thanks JD
If time permits would you be able to give examples of - I would have modeled as-folded to the finished dimensions, probably as a trimmed surface and then Thicken and sheet metal....as mentioned that was the 1st time i used Bend feature so seeing other ways of making Bend features will assist in me modelling better
Cheers,
Tony B
Inventor 2012 EDU
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
