Need to change text style/font
I thought this would be a simple thing to fix, but I'm having difficulty making a change to multiple texts. I received a drawing from another firm that uses different text styles than my firm. I can change all the text styles to mine, but they all hold onto their original fonts. I can't figure out how to change the fonts in multiple instances. Does anyone have any suggestions?
As you've already discovered, if the MTEXT has been modified from it's original style (ie if there are font/properties overrides) the overrides remain even if the style is changed. You can manually delete the over-rides via the Properties Panel, or you can use a lisp routine called "stripmtext" to remove/reset all the formatting in all the selected MTEXTs in one operation.
Thanks, nestly. Is the "stripmtext" lisp routine available on the forum?
