Bobzy20 Posted August 8, 2011 Posted August 8, 2011 I'm drawing this item in 3D AutoCAD and I wanted to see if I'm drawing it right. All the fillets seem to clash with each other and I'm thinking I might have drawn it wrong? Does anybody fancy drawing it and letting me know? For a larger version of the Bevel Gear Support drawing see the link below: http://iadesigns.com.au/53_Bevel_Gear_Support_exercise.jpg Quote
ReMark Posted August 8, 2011 Posted August 8, 2011 Looks like you might have drawn some portion of the part incorrectly that you ended up with the result shown above. Did you go back and check? Quote
Bobzy20 Posted August 8, 2011 Author Posted August 8, 2011 I believe I have drawn this arm (highlighted) wrong but I'm not sure how to draw it from the diagram. Quote
ReMark Posted August 8, 2011 Posted August 8, 2011 Could you have picked the wrong face during the fillet command? Quote
Bobzy20 Posted August 8, 2011 Author Posted August 8, 2011 I had the above measument at 25 but after chnaging it to 12.5 the 25mm fillet seems to fit ok and now meets the edge. Quote
