Autocad 2009 Save As Not Working...need your help
Dear Sir,
Problem: My Autocad 2009 SAVE AS not working properly, when I'm trying to save my work output or anything I want to make SAVE AS it's totally not working...
Is this cause by virus or there something wrong in my software?
Thanks in advance...
Do you get any kind of error message?
Are you saving to a network drive?
Check the value of FILEDIA, if it is set to 0 then set it to 1.
Are you experiencing any other problems, when you try to open a drawing for example?
Are you using illegal software (I only ask because of your request in this thread)?
Illegal software programs have been known to empty your bank account, and send all of your money to Nigeria.
Otherwise, more information is needed.
I believe it is one of the 2009 bugs. Should be a hotfix or update.
Really?
Been using 2009 for a couple of years now, admittedly mine is up-to-date, but I do not remember ever experiencing that issue since day 1.
Really?
Research it yourself. I said "I believe it was a bug" and almost positive another 2009 user had a similar problem not long ago.
I just looked and in similar threads there is "Open Close Save Hotfix for AutoCAD 2009".
No I'm saving in my hard drive....
Did the Hotfix work?
Yes, exactly sir, Im experiencing problem...when Im openning file...there are many informatin..I just click and click enter then I can proceed to the drawing...
No. our company using the LEGAL software...
Thanks everybody problem solve...Our Technician RE-INSTALLED the software again..now its ok
Did the Technician install all the updates as well?
Happy to hear that. :D
