Hi,
I have a block with attributes in it.
The position of the attribute text is not locked so after inserting the block I can move this text to a more readable position.
My problem is that when I edit the block by adding a new attribute, I save the changes, and then use attsync in my drawing where the blocks are, the attribute text that I have already positioned goes back to where it was originally leaving me having to repostion all the text again.
Is this avoidable??
Personally i would put a move parameter on the attribute rather than unlocking it. That should do the trick.
oops sorry your on civil 3D not sure you can do that SORRY
