break circle at one point lisp doesn't work in 2012, anyone?
Any lisp gurus know why this won't work in ACAD2012?
Thanks.
;TIP918: CBRK.LSP ©1993, NOEL DE LA MERCED
; BREAKS A CIRCLE USING A SINGLE POINT.
; ERASES THE ORIGINAL CIRCLE AND DRAWS AN ARC
; THAT HAS THE SAME RADIUS AND CENTER POINT
; AS THE ORIGINAL CIRCLE.
; THIS COMMAND IS A QUICK AND EXCELLENT COMMAND
; FOR HATCHING A CERTAIN PORTION OF A CIRCLE,
; EXAMPLE: FOR GRAPHING.
(DEFUN C:CBRK (/ CMD AA OSN A C D B E F)
(SETQ CMD (GETVAR "CMDECHO"))
(SETVAR "CMDECHO" 0)
(SETQ OSN (GETVAR "OSMODE"))
(COMMAND "OSNAP" "NEAR")
(PROMPT "SELECT CIRCLE TO BREAK ")
(SETQ A (ENTSEL))
(SETQ C (ENTGET (CAR A)))
(SETQ D (CDR (ASSOC 10 C)))
(SETQ CIRC1 (CADR C))
(SETQ CIRC2 (CDR CIRC1))
(SETQ CIRC3 "CIRCLE")
(IF (= CIRC2 CIRC3)
(PROGN
(SETQ AA (GETVAR "UCSORG"))
(COMMAND "UCS" "")
(PROMPT "USE ONE OF THE OSNAP TO BREAK CIRCLE (DEFAULT = NONE) ")
(SETQ B (GETPOINT))
(COMMAND "ERASE" A "")
(COND
((> (CAR D) (CAR B))
(PROGN
(IF (> (CADR D) (CADR B))
(PROGN
(SETQ E (- (CAR B) 0.0000000001))
(SETQ F (+ (CADR B) 0.0000000001))
(PROGN
(SETQ E (+ (CAR B) 0.0000000001))
(PROGN
(PROGN
(SETQ F (- (CADR B) 0.0000000001))
(PROGN
((= (CAR D) (CAR B))
(PROGN
(PROGN
(PROGN
((= (CADR D) (CADR B))
(PROGN
(IF (> (CAR D) (CAR B))
(PROGN
(PROGN
(COMMAND "ARC" "C" (list (car D) (cadr D)) (list (car B) (cadr B)) (list E F))
);PROGN
(PROMPT "\nEntity selected is not a circle.")
);IF
(SETVAR "OSMODE" OSN)
(COMMAND "UCS" "O" AA)
(SETVAR "CMDECHO" CMD)
(PRINC)
); end cbrk.lsp
An ARC entity must have less than 2 x pi radians. -David
