rkent Posted August 15, 2011 Share Posted August 15, 2011 Any lisp gurus know why this won't work in ACAD2012? Thanks. ;TIP918: CBRK.LSP ©1993, NOEL DE LA MERCED ; BREAKS A CIRCLE USING A SINGLE POINT. ; ERASES THE ORIGINAL CIRCLE AND DRAWS AN ARC ; THAT HAS THE SAME RADIUS AND CENTER POINT ; AS THE ORIGINAL CIRCLE. ; THIS COMMAND IS A QUICK AND EXCELLENT COMMAND ; FOR HATCHING A CERTAIN PORTION OF A CIRCLE, ; EXAMPLE: FOR GRAPHING. (DEFUN C:CBRK (/ CMD AA OSN A C D B E F) (SETQ CMD (GETVAR "CMDECHO")) (SETVAR "CMDECHO" 0) (SETQ OSN (GETVAR "OSMODE")) (COMMAND "OSNAP" "NEAR") (PROMPT "SELECT CIRCLE TO BREAK ") (SETQ A (ENTSEL)) (SETQ C (ENTGET (CAR A))) (SETQ D (CDR (ASSOC 10 C))) (SETQ CIRC1 (CADR C)) (SETQ CIRC2 (CDR CIRC1)) (SETQ CIRC3 "CIRCLE") (IF (= CIRC2 CIRC3) (PROGN (SETQ AA (GETVAR "UCSORG")) (COMMAND "UCS" "") (PROMPT "USE ONE OF THE OSNAP TO BREAK CIRCLE (DEFAULT = NONE) ") (SETQ B (GETPOINT)) (COMMAND "ERASE" A "") (COND ((> (CAR D) (CAR B)) (PROGN (IF (> (CADR D) (CADR B)) (PROGN (SETQ E (- (CAR B) 0.0000000001)) (SETQ F (+ (CADR B) 0.0000000001)) ) (PROGN (SETQ E (+ (CAR B) 0.0000000001)) (SETQ F (+ (CADR B) 0.0000000001)) ) ) ) ) (( (PROGN (IF (> (CADR D) (CADR B)) (PROGN (SETQ E (- (CAR B) 0.0000000001)) (SETQ F (- (CADR B) 0.0000000001)) ) (PROGN (SETQ E (+ (CAR B) 0.0000000001)) (SETQ F (- (CADR B) 0.0000000001)) ) ) )) ((= (CAR D) (CAR B)) (PROGN (IF (> (CADR D) (CADR B)) (PROGN (SETQ E (- (CAR B) 0.0000000001)) (SETQ F (+ (CADR B) 0.0000000001)) ) (PROGN (SETQ E (+ (CAR B) 0.0000000001)) (SETQ F (- (CADR B) 0.0000000001)) ) ) ) ) ((= (CADR D) (CADR B)) (PROGN (IF (> (CAR D) (CAR B)) (PROGN (SETQ E (+ (CAR B) 0.0000000001)) (SETQ F (+ (CADR B) 0.0000000001)) ) (PROGN (SETQ E (- (CAR B) 0.0000000001)) (SETQ F (- (CADR B) 0.0000000001)) ) ) ) ) ) (COMMAND "ARC" "C" (list (car D) (cadr D)) (list (car B) (cadr B)) (list E F)) );PROGN (PROMPT "\nEntity selected is not a circle.") );IF (SETVAR "OSMODE" OSN) (COMMAND "UCS" "O" AA) (SETVAR "CMDECHO" CMD) (PRINC) ); end cbrk.lsp Quote Link to comment Share on other sites More sharing options...
David Bethel Posted August 15, 2011 Share Posted August 15, 2011 An ARC entity must have less than 2 x pi radians. -David Quote Link to comment Share on other sites More sharing options...
