devonhead
Plotting wipeouts in pdf
devonhead
I like using wipeouts in adding text over busy sections of plant layouts. When they are printed as an pdf on an A3 they usually print fine. If the pdf is printed as an A1 or AO then the wipeouts have like a solid hatch pattern over them. I would like to continue using wipeouts to add text over details on a drawing if possible. Has anybody else experienced this problem and have they found a solution?
Share this post
Link to post
MSasu
Seems that the solution is to use the AutoCAD built-in virtual PDF printer.
Regards,
Mircea
Share this post
Link to post
devonhead
Regards,
Mircea
Thanks for the advise. I have used the AutoCAD PDF printer previously but had other issues with it. I will try again.
Thanks again
Share this post
Link to post
Organic
Wipeouts are a real pain for this reason alone and in my opinion should not be used at all.
Share this post
Link to post
Adju
I had some issues in the past but a good trick is to change the color of the wipeout by using "255". Works for me in the past.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
