rwsice9 Posted August 19, 2011 Share Posted August 19, 2011 OK LISP Masters! I have this one ALMOST where I need it. (some of the functions are still incomplete, but I know how to get those to work). Here is what this lisp is supposed to do. You are presented with a dialog box with options for device type, and other device options, then based on your options, it inserts a block, adds your other picked options, then keeps going. When you right click, the dialog should return, letting you pick different options, so you can insert different blocks. I have the whole thing working, EXCEPT for the "right click to return the dialog". Can anyone please help? (defun c:notif(/ :dlgId :done);new combined notification (setq CVR (getvar "useri2") SCL (GETVAR "userr1") lyr (getvar "clayer") osm (getvar "osmode") ) (if (= 0 scl)(command (alert "Please Set your scale and try agagin")(exit))) (COMMAND "OSMODE" "514") (COMMAND "-LAYER" "s" "F-ALRM-INDC" "") (setq :dlgId (load_dialog "notif.dcl")) (setq :done 3) (while (/= :done 0) (if (not (new_dialog "DLG_Notif" :dlgId)) (exit) ) (action_tile "devStrobe" "(setq dev 1)") (action_tile "devHRNStrobe" "(setq dev 2)") (action_tile "devSPKStrobe" "(setq dev 3)") (action_tile "devHorn" "(setq dev 4)") (action_tile "devSpeaker" "(setq dev 5)") (action_tile "mtWall" "(setq mt 1)") (action_tile "mtCeil" "(setq mt 2)") (action_tile "cd15" "(setq cd 15)") (action_tile "cd30" "(setq cd 30)") (action_tile "cd75" "(setq cd 75)") (action_tile "cd95" "(setq cd 95)") (action_tile "cd110" "(setq cd 110)") (action_tile "cd135" "(setq cd 135)") (action_tile "cd177" "(setq cd 177)") (action_tile "cd185" "(setq cd 185)") (action_tile "wat25" "(setq wat 4)") (action_tile "wat5" "(setq wat 5)") (action_tile "wat1" "(setq wat 1)") (action_tile "wat2" "(setq wat 2)") (action_tile "wat75" "(setq wat 7)") (action_tile "lensClear" "(setq lens 1)") (action_tile "lensAmber" "(setq lens 2)") (action_tile "lensCombo" "(setq lens 3)") (action_tile "spcWP" "(setq wp 1)") (action_tile "spcWG" "(setq wg 1)") (action_tile "accept" "(done_dialog 1)") (action_tile "cancel" "(done_dialog 0)") (setq :done (start_dialog)) (cond ((= :done 1) (setvar "cmdecho" 0) (if (= wat 4)(setq watt ".25W")) (if (= wat 5)(setq watt ".5W")) (if (= wat 1)(setq watt "1W")) (if (= wat 2)(setq watt "2W")) (if (= wat 7)(setq watt "7.5W")) (setq :txting 0) (while (= 0 :txting) (initget 0) (if (= dev 1) (progn (COMMAND "_.-INSERT" "FA_STROBE_ONLYW" pause SCL "" pause CD) (setq :txting 0))(setq :txting 1)) (if (= dev 2) (COMMAND "_.-INSERT" "FA_Hornstrobe" pause SCL "" pause CD)) (if (= dev 3) (COMMAND "_.-INSERT" "FA_Speakerstrobe" pause SCL "" pause CD watt)) ) (setvar "cmdecho" 1) );done ((= :done 0) (prompt "\nEnd notification command.") ) );cond ; (if (= 1 cvr)(command "-layer" "s" "F-STRB-COVR" "")) ; (setq elast (entlast)) ; (IF (= 1 CVR)(command "_.-insert" "sg-15cd" "_non" ; (cdr (assoc 10 (entget elast))) "1" "" (* 180. (/ (cdr (assoc 50 (entget elast))) pi)))) ); while (unload_dialog :dlgId) (COMMAND "CLAYER" LYR) (COMMAND "OSMODE" OSM) (princ) ) I also have the LISP and DCL files attached. NOTIF.LSP notif.dcl Quote Link to comment Share on other sites More sharing options...
Lee Roy Posted August 19, 2011 Share Posted August 19, 2011 I would venture to something along the lines of... (if *reopen* (progn (setq *reopen* nil) (vlr-remove-all :vlr-mouse-reactor) ); /progn ); /if (if (not *reopen*) (setq *reopen* (vlr-mouse-reactor nil '((:vlr-beginrightclick . reopendiag)))) ); /if (defun reopendiag (<rea> <args>) (:dlgId) (princ) ); /defun I'm not "master" (long shot from it), so the masters may have better solution. I'm just stuck at terminating the right click reactor when done with the command; how to trigger (vlr-remove-all :vlr-mouse-reactor) off the Cancel button, maybe. Quote Link to comment Share on other sites More sharing options...
