Dear friends.
I want to know how could using autolisp divide a drawing into equal parts (eg, 9, dividing the drawing in 3x3), 9 DWGs automatically creating a specific folder, and keeping the original coordinates, ie is re-inserted on a new new dwg , to bond perfectly.
Note: no need to trim the division of the drawings. What matters to me is not to lose information. Thanks for the help.
Sorry my bad english.
I would approach it in the following way:
  • Get Extents of drawing
  • Prompt for Number of Divisions (must be square integer, otherwise prompt for length of one side)
  • Calculate coordinates for each window
  • Obtain SelectionSet using Window/Crossing selection.
  • WBlock objects in the Selection Set.
Here is an example using the same approach to create separate drawings for each layer in a drawing.
PS. Labelling your thread as 'Urgent' will not result in a quicker answer, usually such threads are even avoided by most members.
I understand what you mean. But the urgency is real. In times had a lisp that made it, but my computer broke and I lost the file. If anyone can help me I would be very grateful.
Greetings.
This will allow you to quickly WBlock a selection:
(defun c:wb ( / _uniquefile doc fnm ) (vl-load-com)
   (defun _uniquefile ( seed extn / i file )
       (setq i 0)
       (while (findfile (setq file (strcat seed (itoa (setq i (1+ i))) extn))))
       file
   (setq doc (vla-get-activedocument (vlax-get-acad-object))
         fnm (strcat (getvar 'DWGPREFIX) (vl-filename-base (getvar 'DWGNAME)) "_")
   (while (ssget)
       (vla-wblock doc (_uniquefile fnm ".dwg") (vla-get-activeselectionset doc))
But that's as far as I'm prepared to take it on voluntary time.
Please do not repent to help someone.
You just saved my day.
:notworthy: Thank you.
