MPagan Posted August 22, 2011 Posted August 22, 2011 My company is use\ing LDD2009, as well as map. when we make notations in our plans we use a block that is basicly a square with an attribute inside to represent a number, the nuber then corresponds to the same number and a description in a table. Now, I have been asked to create / recreate (a)the block that would rotate per viewport, also; we are not usin dynamic leaders. is there a way to either continue with the block or create a dynamic leader that would rotate per viewport, even in other drawings that have xrefs attached like Plan & Profile sheets that are separate drawings. I'm not sure how autocad would handle the rotating as well as the location of the block and still have the leader point in the same place. any ideas? Quote
SLW210 Posted August 22, 2011 Posted August 22, 2011 Could you post a screen shot of a before and after? Quote
