ALPDIA Posted August 22, 2011 Posted August 22, 2011 Working in a drawing that leaves an X at the measured node instead of a point. How can I change this? Quote
CyberAngel Posted August 22, 2011 Posted August 22, 2011 The long answer is that the format of points is controlled by the PDMODE system variable. Your drawing probably has PDMODE set to 3, so points always appear as Xs. By changing the value, you can change the appearance of points. Check your Help for all the possible values. A related variable is PDSIZE, which becomes relevant if points will appear as something besides dots. Quote
