honestbud Posted August 25, 2011 Posted August 25, 2011 hi everyone. hope i write in right place. i have a question : i make a new command and put it into one panel and it is work. i wrote a macro like that : ^C^Cline or somthing more complex but when i type it's name it in command line, it dosn’t run anything. is that normal? i like to create some custome command that i can type them in command line.is there any way!? (maybe i should use acad.pgp file!) thanks Quote
ReMark Posted August 25, 2011 Posted August 25, 2011 Maybe you are mixing things up a bit. A command alias belongs in the acad.pgp file. A macro can be assigned to a button like you did. Not sure why you need a button/macro for the line command though. The other option is a lisp routine. Quote
honestbud Posted August 25, 2011 Author Posted August 25, 2011 i like to create my costume command. for example i want to rotate one line in a specefic angel. this angel goes from multipying two number. i must calculate these numbers by my calculator then enter them into CAD. i like to create a command that start with this number then multipying them and then rotate the line with result of multipying.after create i like to type this command in command line. can i do it with custom command? if answer is NO, i leave this idead alone. Quote
ReMark Posted August 25, 2011 Posted August 25, 2011 For the sake of clarity... Use the word "custom" not costume and the word "angle" not angel. Thanks. For what you are attempting to do a command alias would not be the best option. You want to use either a macro or a lisp routine. In either case you'll have to pause for user input. Quote
honestbud Posted August 26, 2011 Author Posted August 26, 2011 For the sake of clarity... Use the word "custom" not costume and the word "angle" not angel. Thanks. For what you are attempting to do a command alias would not be the best option. You want to use either a macro or a lisp routine. In either case you'll have to pause for user input. thanks.sorry for dictation. now i cant search and learn macro or a lisp routine.thanks for help Quote
