Lt Dan's legs Posted August 26, 2011 Posted August 26, 2011 (edited) I am trying to figure out a way to add an object to a dynamic block (flip parameter). If you watch the video within reactor.zip you will see the Dynamic Door block. I just want to know two things 1. Is vla-sendcommand "bedit" the only way to access the Action Entities? 2. is vla-sendcommand stupid idea within an object reactor? PS I know doing a 3d door would solve my problem but I work with old guys and they refuse to stray away from 2d. reactor.zip Edited September 2, 2011 by Lt Dan's legs Quote
SOliver Posted August 29, 2011 Posted August 29, 2011 Hi, Watched the video and I look forward to seeing the end result. I think what you're looking for is the 'vla-getDynamicBlockProperties' method. It's use may require that you staple a dictionary to either each block or the collection of the two blocks and text field. I wouldn't recommend using the vla-sendCommand, any task you can comprehend that implements it can be done using the vl* methods without it. Hope this helps, SOliver Quote
Lt Dan's legs Posted September 1, 2011 Author Posted September 1, 2011 Watched the video and I look forward to seeing the end result. test.zip I'll just have to do this as a command custom command I had to use command calls to do it Quote
Lt Dan's legs Posted September 2, 2011 Author Posted September 2, 2011 Hi,I think what you're looking for is the 'vla-getDynamicBlockProperties' method. Actually, I was looking for this (see below). You cannot add an object to the action entity this way. Anyone know how? I want to avoid using (command "_.bedit" etc. ;if flag = t ;will return a list of action parameter's as entities ;if flag= nil ;will return an entity list of "ACAD_EVALUATION_GRAPH" ;;example: (evalgraph "door" t) ;| or |; (evalgraph "door" nil) (defun EvalGraph ( blockname flag / l eg ) (if (and (setq l (vla-item (vla-get-blocks (ad)) blockname)) (eq :vlax-true (vla-get-HasExtensionDictionary l)) ) (vlax-for x (vla-GetExtensionDictionary l) (if (eq "AcDbEvalGraph" (vla-get-ObjectName x)) (setq eg ( (lambda ( g ) (if flag (mapcar (function cdr) (vl-remove-if-not (function (lambda ( x ) (eq (car x) 360) ) ) g ) ) g ) ) (entget (vlax-vla-object->ename x)) ) ) ) ) ) eg ) Quote
