I would like to learn to make lisp programs. Is there any way to get learning briefly. I am a new one to Auto lisp.
Plenty of books available also.
My favorite book at the moment is David M. Stein's Visual LISP Developer's Bible, 2011 Edition... still only $6.99 from Amazon ;)
Also, don't forget about the LISP Developer Documentation, either F1 from VLIDE, or:
(defun c:LISPDD () (c:LISPDeveloperDocumentation))
(defun c:LISPDeveloperDocumentation  ()
 (princ "\rLISP DEVELOPER DOCUMENTATION ")
 (vl-load-com)
 ((lambda (vrsn)
    (help
      (strcat
        "acad_dev"
        (cond
          ((vl-string-search "16.2" vrsn) "162")                       ; 2006
          ((vl-string-search "17.0" vrsn) "170")                       ; 2007
          ((vl-string-search "17.1" vrsn) "171")                       ; 2008
          ((vl-string-search "17.2" vrsn) "172")                       ; 2009
          ((vl-string-search "18.0" vrsn) "180")                       ; 2010
          ((vl-string-search "18.1" vrsn) "181")                       ; 2011
          ((vl-string-search "18.2" vrsn) "182")))))                   ; 2012
   (vlax-product-key))
 (princ))
Edited by BlackBox
Code simplified
After reading the books and help etc as a start set yourself a goal for a program in lisp best way to learn !
Start simple think about how you would do it manually and write down the steps, if it involves a lot of pt calculations draw a diagram so you know what variables you have used and where they are.
If you have an idea of something you want post it here and at least you should get advice about how to approach the problem write some code then and help will follow.
  • 2 weeks later...
Thank you friend...I will follow the same
More AutoLISP tutorials can be found here....http://www.jefferypsanders.com/autolisp.html
