Same Viewport - Multiple Drawings
tigerlilygirl
I have 5 drawings that all have the same model (basically a topo map of a 2 mile radius) but each have unique info, i.e. monitoring well locations, utility info, etc. The client wants a zoomed in view of a 1 block radius and I need all 5 drawings to have an identical zoom. How do I adjust my viewports in each drawing so they are zoomed in to the exact same place?
I'm using AutoCAD 2007 for this.
Use ZOOM > OBJECT and pick an object that you want to define the center of the view, then change your viewport scale as needed (the view will remain centered on that object)
