bass_mark00 Posted August 29, 2011 Posted August 29, 2011 I need to work on a set of floorplans which have been created in Architecture but need to be edited by users using AutoCAD. Exploding causes too much damage, is there a quick method of reducing everything to 2D and making it suitable for editing in AutoCAD? (similar to bursting attributes) Thanks Mark Quote
ReMark Posted August 29, 2011 Posted August 29, 2011 FLATSHOT, SECTIONPLANE and SOLPROF are three options available to you. Quote
SLW210 Posted August 29, 2011 Posted August 29, 2011 Export to AutoCAD or something like that I forgot the command. A quick search should find it. Quote
bass_mark00 Posted August 29, 2011 Author Posted August 29, 2011 Thanks ReMark, I think FLATSHOT is probably going to be best. SECTIONPLANE probably won't offer the required flexibility and with SOLPROF I think I'll lose the benefits of the existing layers. I'll give it a go. Thanks Quote
bass_mark00 Posted August 29, 2011 Author Posted August 29, 2011 Export to AutoCAD or something like that I forgot the command. A quick search should find it. Thanks I'll give EXPORT a go, that would make a lot of sense. Just waiting for the file to be emailed through. Mark Quote
tzframpton Posted August 29, 2011 Posted August 29, 2011 Best way to do it is through the EXPORT option. If you're in a Top View and export, it will flatten everything as 2D linework. If you're in any other type of view, including a 3D Orbited view, then it will export as solids and not as AEC Objects. Quote
bass_mark00 Posted September 4, 2011 Author Posted September 4, 2011 Thanks very much, EXPORT got us exactly what we wanted. Quote
