Guys,
I have no experience with creating dynamic blocks and I have been looking for help in creating one. I have attached a basic PTZ block and what I want it to do is when I rotate the block past a certain point +/-90 degrees the text rotate within the rectangle so it's never upside down.
Can I get any direction on what route I need to take to get this done?
PTZ.dwg
I'm not sure about having just one parameter to accomplish this, however here are a few ideas that might help in resolving this issue. PTZ_1 just rotates the block, excluding the text with a point move parameter so you can move the text to a desired location. PTZ_2 is a little more complex, but not by much; You have a rotation parameter again set to increment in 5 deg and a limitation on how far it can turn. The block also has a flip parameter to flip the block when you need to have it point in the back/front side of the 180 deg. There are probably a dozen other ways to accomplish this, but these were the simplest ways I could think of. You could use more parameters and a look up table to get this perfectly the way you want it.
PTZ_1.dwg
PTZ_2.dwg
