Hi All,
Is there a way to select all instances of a dynamic block in the drawing by picking one?
This is an attempt to "Select by name". But dynamic blocks kills my code below as they have fancy naming (Like *U24)
So far I am here...
(defun c:SB ()
 (setq TargEnt (car (entsel "\nSelect block : ")))
 (setq blkname (EffectiveName TargEnt))
 (setq ss (ssget "_X" (list (cons 0 "insert")(cons 2 blkname))))
 (sssetfirst nil ss)
;Code below is the courtesy of 'irneb' on http://forums.augi.com/showthread.php?t=114752
(defun EffectiveName (en / ed d1 d2 d3 br)
 (setq ed (entget en))
 (setq d1 (entget (cdr (assoc 360 (member '(102 . "{ACAD_XDICTIONARY") ed)))))
 (setq d2 (entget (cdr (assoc 360 (member '(3 . "AcDbBlockRepresentation") d1)))))
 (setq d3 (entget (cdr (assoc 360 (member '(3 . "AcDbRepData") d2)))))
 (setq br (entget (cdr (assoc 340 d3))))
 (cdr (assoc 2 br))
Select your single block instance, and extract the block's name, then create a selection set of all blocks with that, or annonymous names. Next iterate through that selection set and check for matches against the original block's EffectiveName and IsDynamicBlock Properties.
Sample:
(setq ss (ssget "x" (list (cons 2 "[color=red]<BlockName>[/color],`*U*"))))
HTH
This post demonstrates two methods to acquire a SelectionSet of the required blocks. This may also help with regards to the Effective Block Name.
I made the same question long ago... I couldn't remember who helped me then...
(defun c:sb    (/ e name n out ss x rjp-getblockname)
(vl-load-com)
(prompt "\n   Pick BLOCK to acquire its instances in the drawing...")
 (defun rjp-getblockname (obj)
   (if    (vlax-property-available-p obj 'effectivename)
     (vla-get-effectivename obj)
     (vla-get-name obj)
 (if (setq x     (ssget '((0 . "INSERT")))
       x     (ssname x 0)
       name (rjp-getblockname (vlax-ename->vla-object x))
       ss     (ssget "_X" '((0 . "INSERT")))
       n     -1
       out     (ssadd)
   (while (setq e (ssname ss (setq n (1+ n))))
     (if (= (rjp-getblockname (vlax-ename->vla-object e)) name)
   (ssadd e out)
 (sssetfirst nil out)
