I have a drawing i need to simply change the leading letters of the layer (C-***) to V-***.
anyway to Find and Replace?
  • Replies 21
  • alanjt
    7
  • Tharwat
    6
  • BlackBox
    5
  • baker
    3
Posted Images
Try this baker and it is case sensitive which means ( c- (small letter) is not equal to C- (capital letter)) .
Codes better than Command calls . :D
(defun c:TesT (/ nxt layrs Nme)
 ;; == TharwaT 01. 09. 2011 == ;;
 (while
   (setq nxt (tblnext "LAYER" (null nxt)))
    (setq
      layrs
       (entget (tblobjname "LAYER" (setq Nme (cdr (assoc 2 nxt)))))
    (if (and (not (eq Nme "0"))
             (eq (vl-string-search "C-" Nme 0) 0)
      (entmod
        (subst (cons 2 (vl-string-subst "V-" "C-" (cdr (assoc 2 layrs))))
               (assoc 2 layrs)
               layrs
Tharwat
*cough* wcmatch *cough*
But I try not to re-invent the wheel where possible ;)
I have thought of that as another access to Layer name matches and I do agree that the function wcmatch is much better than vl-string-search in this case .
Anyway here it goes .
Comments are also welcomed . :)
 (while
    (setq
      layrs
             (wcmatch Nme "C-*")
      (entmod
               (assoc 2 layrs)
               layrs
Tharwat,
Not that you have to of course, but out of curiosity... if you're not going to use the RENAME command, and you're going to use vl-* functions, then why not just iterate the Layers Collection instead? :unsure:
Pseudo code:
((lambda (acDoc / )
 (vlax-for lay (vla-get-layers acDoc)
   [color=seagreen];;<-- Check / rename layers here[/color]
 (vla-get-activedocument (vlax-get-acad-object)))
If you have many layers (maybe Hundreds) in a dwg , the command call would be lazy .:)
Both are the same , aren't they ?
One more routine in Vl .:)
(defun c:TesT (/ lays Nme)
 (setq lays (vla-get-layers
 (vlax-for x lays
   (if (wcmatch (setq Nme (vla-get-name x)) "C-*")
     (vla-put-name x (vl-string-subst "V-" "C-" Nme))
Regards,
Tharwat
I have forgotten that Multiple Selection method is allowed in Rename Command . :thumbsup:
Work smart, not hard.
Nice saying .
When being overwhelmed by lots of projects to hand over on time , there won't be time to spend on thinking than keep on working (sometimes) :lol:
Nice saying .
Then maybe you should spend more time working and less time trolling the forums. ;)
There must a few seconds to get some fresh air , to be able to carry on and to keep the brain a live .:shock:
Quick, step outside.
I am an idiot!!! thank you guys for being patient and supportive!!
*US*
We'll whip you numpties into shape, one way or another! :P :rofl: LoL
^^ Just being sarcastic, of course. Please take no offense.
none taken.. i own a VW enthusiasts forum and we toss poo at each other all the time!! all in good fun!
^^ Gold, that is. :rofl:
I'm glad you share the sense of humor; you *should* fit in nicely.
Man, this thread seems to have take a sh!77y direction and done down the toilet. :P
I hate it when things 'done down the toilet'. :rofl:
