This is a script type routine I run on drawings created in Solidworks.
I get dimensions with all sorts of different DIMSTYLES.
I want to change them all to Standard.
Here's what I have so far..
I don't know how to change (3."xxxx") to (3."Standard")
Also, can you do a TBLSEARCH for several items at once? :cry:
(DEFUN C:SWDX ()
(Prompt "Change SW Lines:")
(setq ss4 (ssget "x" '((0 . "LINE")(6 . "PHANTOM"))))
(setq TEST (tblsearch "LAYER" "X25"))
    (if (= TEST nil)
                 (Command "-layer" "n" "X25" "C" "RED" "X25" "")
(command "CHANGE" ss4 "" "p"  "la" "X25" "c" "bylayer" "lt" "Phantom" "LW" "default" "")
(setq ss5 (ssget "x" '((0 . "DIMENSION"))))
(setq TEST (tblsearch "LAYER" "DIM"))
    (if (= TEST nil)
                 (Command "-layer" "n" "DIM" "C" "RED" "X25" "")
(command "CHANGE" ss5 "" "p"  "la" "DIM" "c" "bylayer" "LW" "default" "")
[b];;; Need to change (3."xxxx") to (3. "Standard") for SS5[/b]
(setq ss9 (ssget "x" '((0 . "LINE")(6 . "*CENTER*"))))
(command "ERASE" ss9 "")
(princ))
I know my code writing skills are very elementary... :oops:
If there's a better way to do what I've done, I'm open.
If someone wants to just fill in the blanks that's fine too...
Thanks!
You need to use function *entmod* to change dimstyles . .... :)
(defun c:Test (/ ss i sset e)
 (if (setq ss (ssget "x" '((0 . "DIMENSION"))))
   (repeat
     (setq i (sslength ss))
      (setq sset (ssname ss (setq i (1- i))))
      (if (not (eq (cdr (assoc 3 (setq e (entget sset)))) "Standard"))
        (entmod (subst (cons 3 "Standard") (assoc 3 e) e))
Tharwat
Thanks...
What about the TBLSEARCH question?
Is it possible to TBLSEARCH for several items at once?
ie: check for several layers??
No, you must search each name individually. -David
Just an aside, you can use ( entmod / append ) to modify all of the entities:
[b][color=BLACK]([/color][/b]defun c:swdx [b][color=FUCHSIA]([/color][/b]/ ss4 ss5 en ed[b][color=FUCHSIA])[/color][/b]
 [b][color=FUCHSIA]([/color][/b]if [b][color=NAVY]([/color][/b]not [b][color=MAROON]([/color][/b]tblsearch [color=#2f4f4f]"LAYER"[/color] [color=#2f4f4f]"X25"[/color][b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b]
     [b][color=NAVY]([/color][/b]command [color=#2f4f4f]"_.LAYER"[/color] [color=#2f4f4f]"_N"[/color] [color=#2f4f4f]"X25"[/color] [color=#2f4f4f]"_C"[/color] [color=#2f4f4f]"RED"[/color] [color=#2f4f4f]"X25"[/color] [color=#2f4f4f]""[/color][b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b]
 [b][color=FUCHSIA]([/color][/b]if [b][color=NAVY]([/color][/b]setq ss4 [b][color=MAROON]([/color][/b]ssget [color=#2f4f4f]"_X"[/color] '[b][color=GREEN]([/color][/b][b][color=BLUE]([/color][/b]0 . [color=#2f4f4f]"LINE"[/color][b][color=BLUE])[/color][/b][b][color=BLUE]([/color][/b]6 . [color=#2f4f4f]"PHANTOM"[/color][b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b]
     [b][color=NAVY]([/color][/b]command [color=#2f4f4f]"_.CHPROP"[/color] ss4 [color=#2f4f4f]""[/color] [color=#2f4f4f]"_LA"[/color] [color=#2f4f4f]"X25"[/color] [color=#2f4f4f]"_LW"[/color] [color=#2f4f4f]"Default"[/color] [color=#2f4f4f]""[/color][b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b]
 [b][color=FUCHSIA]([/color][/b]and [b][color=NAVY]([/color][/b]setq ss5 [b][color=MAROON]([/color][/b]ssget [color=#2f4f4f]"_X"[/color] '[b][color=GREEN]([/color][/b][b][color=BLUE]([/color][/b]0 . [color=#2f4f4f]"DIMENSION"[/color][b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b]
      [b][color=NAVY]([/color][/b]tblsearch [color=#2f4f4f]"DIMSTYLE"[/color] [color=#2f4f4f]"STANDARD"[/color][b][color=NAVY])[/color][/b]
      [b][color=NAVY]([/color][/b]while [b][color=MAROON]([/color][/b]setq en [b][color=GREEN]([/color][/b]ssname ss5 0[b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b]
             [b][color=MAROON]([/color][/b]setq ed [b][color=GREEN]([/color][/b]entget en[b][color=GREEN])[/color][/b]
                   ed [b][color=GREEN]([/color][/b]subst '[b][color=BLUE]([/color][/b]3 . [color=#2f4f4f]"STANDARD"[/color][b][color=BLUE])[/color][/b] [b][color=BLUE]([/color][/b]assoc 3 ed[b][color=BLUE])[/color][/b] ed[b][color=GREEN])[/color][/b]
                   ed [b][color=GREEN]([/color][/b]subst '[b][color=BLUE]([/color][/b]8 . [color=#2f4f4f]"DIM"[/color][b][color=BLUE])[/color][/b]      [b][color=BLUE]([/color][/b]assoc 8 ed[b][color=BLUE])[/color][/b] ed[b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b]
             [b][color=MAROON]([/color][/b]if [b][color=GREEN]([/color][/b]assoc 62 ed[b][color=GREEN])[/color][/b]
                 [b][color=GREEN]([/color][/b]setq ed [b][color=BLUE]([/color][/b]subst '[b][color=RED]([/color][/b]62 . 256[b][color=RED])[/color][/b] [b][color=RED]([/color][/b]assoc 62 ed[b][color=RED])[/color][/b] ed[b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b]
             [b][color=MAROON]([/color][/b]if [b][color=GREEN]([/color][/b]assoc 370 ed[b][color=GREEN])[/color][/b]
                 [b][color=GREEN]([/color][/b]setq ed [b][color=BLUE]([/color][/b]subst '[b][color=RED]([/color][/b]370 . -3[b][color=RED])[/color][/b] [b][color=RED]([/color][/b]assoc 370 ed[b][color=RED])[/color][/b] ed[b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b]
                 [b][color=GREEN]([/color][/b]setq ed [b][color=BLUE]([/color][/b]append ed '[b][color=RED]([/color][/b][b][color=PURPLE]([/color][/b]370 . -3[b][color=PURPLE])[/color][/b][b][color=RED])[/color][/b][b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b]
             [b][color=MAROON]([/color][/b]entmod ed[b][color=MAROON])[/color][/b]
             [b][color=MAROON]([/color][/b]ssdel en ss5[b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b]
[b][color=FUCHSIA]([/color][/b]prin1[b][color=FUCHSIA])[/color][/b][b][color=BLACK])[/color][/b]
Edited by David Bethel
