123 Posted October 13, 2008 Posted October 13, 2008 Hello, when i put transparented gif to dwg but its nontransparent (pic1). i change transparent to yes from properties that's ok(pic2) but autocad make black storake automatic. i dont want to it. i change color to white (pic3) and i partly remov it but when the image on the black color backround white stroke will turn visible. How can i completely remove it? Pic 1 Pic 2 Pic 3 Quote
123 Posted October 13, 2008 Author Posted October 13, 2008 tankyou for your answer; but i cant find "imageframe" . Could you tell me where i can find this. Quote
feargt Posted October 13, 2008 Posted October 13, 2008 just type imageframe, pretty sure that works in acad 2004, set value to 0. Quote
feargt Posted October 13, 2008 Posted October 13, 2008 not sure why I said 2004...... Also if u right click on any of the standard toolbars, u should see a list of available toolbars, there should be one called reference. The image frame command should also be found here, at least it is in 2008 Quote
123 Posted October 13, 2008 Author Posted October 13, 2008 its working thank you very much so i have one question more i dont want to always turn transparety to on and imageframe to 0. How can i automatic do this? Quote
feargt Posted October 13, 2008 Posted October 13, 2008 if you use a drawing template for your drawings you can change the settings here to suit your needs, then when u start the next drawing using the template, the settings will be as u want Quote
123 Posted October 13, 2008 Author Posted October 13, 2008 i dont use templates. finished projects come to me and i put some pics. i dont want to do this steps every time. So how can i do this? Quote
