kevin1973 Posted September 13, 2011 Posted September 13, 2011 I have 2 viewports. 1 view from the front and another from the side. Is it possible to "hide" the front then hide the other side without it affecting what was just hidden in the other view? This is going to be for printing purposes only. Quote
SLW210 Posted September 13, 2011 Posted September 13, 2011 Is this a 3D model? You could always assign different layers and freeze by viewport. You also have a Hidden Visual Style. Quote
CyberAngel Posted September 13, 2011 Posted September 13, 2011 If this will be an ongoing situation, you might consider using two different layouts, each of which is permanently set up to show what you want. That might be easier than changing the viewports every time you plot. Quote
kevin1973 Posted September 13, 2011 Author Posted September 13, 2011 That's exactly what I was thinking. Using 2 different Layouts. Thanks y'all. Quote
