fostertom Posted October 13, 2008 Posted October 13, 2008 I have layers called e.g Con-Blockwork and layers called e.g. Con-Blk-Site. No prob creating Layer filters to display only Con's and Blk's respectively - but the Con's include the Con-Blk's. I can't work out how to make the ~ exclude the Con-Blk's from the Con's. Quote
rkent Posted October 14, 2008 Posted October 14, 2008 I have layers called e.g Con-Blockwork and layers called e.g. Con-Blk-Site. No prob creating Layer filters to display only Con's and Blk's respectively - but the Con's include the Con-Blk's. I can't work out how to make the ~ exclude the Con-Blk's from the Con's. It doesn't look like you need the ~ at all, one filter would be CON-BLK*, and another would be CON-BLO*. Quote
fostertom Posted October 14, 2008 Author Posted October 14, 2008 Yeah but I've got lots of Con's, like Con-Ashlar, Con-Fittings etc, which only filter Con* will select - but that also selects the Con-Blk's, which I want to exclude. Quote
fostertom Posted October 14, 2008 Author Posted October 14, 2008 No, sadly it doesn't. In Layer filter Properties under Name, in 1st line I have Con*; in 2nd line I have ~Con-Blk*. All the Con-Blk layers still show, as well as the Con layers Quote
rkent Posted October 14, 2008 Posted October 14, 2008 The first and only line should be ~con-blk* Quote
fostertom Posted October 14, 2008 Author Posted October 14, 2008 Then I get everything that isn't Con-Blk*, which includes my Ex layers E.g. Ex-Walls, Ex-Roof - which I only want to see in my Ex* layer filter. So it's not possible to set up a layer filter which includes Con* but excludes Con-Blk*? Quote
