If I create a Box using two points, how do I display the position using the first point?
Welcome in the forum!
Do you mean the position of the second point relative to the first point? With other words, are you interested in finding the three dimensions of the box?
If I create a box with the first point being X=2000, Y=-2000, and Z=-4000 I want this to be the position of the box displayed in the properties instead of the center points on each axis.
Use ID command, using osnap endpoint or intersection grab that point.
When I open the properties of the box I create, I need the geometry coordinates to all reflect the first point position. At the moment only Z gives me the right position. X and Y axes give me the mid point between my two creation points instead of the first origin point.
Got it. If I create a Block out of my box I can select the origin and then it will display correctly when I open the properties for the block. Thanks.
