gejaystudent
Imperial to metric ...can this be changed after install?
gejaystudent
Hey hi all, maybe i should poke a stick in my eye because the answer is looking at me. I'll bet but heres my first question...
I have created a project in a metric template, then found that the scale factor is haywire. Is there some way to rest the template with out loosing my work or changing anything other than the physical line properties?
Second, I have loaded the same file onto another students file who's scale factor is A OK and metric. My file LOOKS fine but when i start to add lines or dimension all the properties are imperial!
Thanks for reading,
gejay.
Share this post
Link to post
rkent
Type UNITS hit enter, change the type to decimal. You may have to go into dimstyle and change the Primary units, Unit format as well.
Share this post
Link to post
gejaystudent
Thanks I'll give that a go.
I have gone into CUI and the units on the toolbar tab and changed but to no avail.
Share this post
Link to post
gejaystudent
Thank you! problem solved!
Now, we were wondering, is there a button called 'do my homework for me'?
just putting it out there!
Thanks again.
Share this post
Link to post
ReMark
We won't do your homework for you (at least most of us won't) but we will try to answer your questions to the best of our ability.
Share this post
Link to post
SLW210
Like ReMark said, most are not going to do the homework for you, but you some will walk you step-by-step through your projects. Just start searching and asking questions.
Share this post
Link to post
gejaystudent
what a great bunch of dedicated people! Thanks again from downunder.
Share this post
Link to post
