I am using autocad 2011 and have been using a dynamic block for calling out sections in floor plans. I can see the blocks in model space but not in paper space, and the layer is on in paper space. Is there any property, attribute or else that I need to change in order to make it visible in paper space?
Just to be clear, are you sure the layer is thawed/on in the viewport, not just on the (Paperspace) layout tab?
Is the block annotative? If so, does it have an annotative scale that matches your viewport?
Thanks. I needed to change the annotative scale to match the viewport scale. :)
