Ahankhah
How to distinguish between Ellipse and Ellipse Arc?
Ahankhah
Hi CADmates,
how is it possible to recognize an ellipse object is closed (i.e. full ellipse) or open (i.e ellipse arc)?
Any reply appreciated.
Share this post
Link to post
pBe
(if
(= StartAngle 0)
(Closed/FullEllipse)
(Open/EllipseArc)
Share this post
Link to post
Tharwat
My approach ...
(vlax-curve-IsClosed (car (entsel "\n Select Ellipse :")))
If Yes T . nil otherwise
Share this post
Link to post
pBe
Good one tharwat
I didint know that one :)
Share this post
Link to post
Tharwat
Good one tharwat
Thank you pBe ,
I knew these functions which are start with vlax-curve-****** when I was fighting with Polylines to know how to handle them .:lol:
So no chance to forget them anymore . :lol:
Cheers . :beer:
Share this post
Link to post
Ahankhah
pBe and Tharwat,
thank you very much for your help.
Meanwhile I researched inside Ellipse and Ellipse Arc lists. I found a dxf code inside them which shows whether ellipse is closed or not.
The advantage of the following code is filtering them automatically or on the fly (when selecting objects).
(setq ellipses
 (ssget "X"
   (list
     (cons -4 "<AND")
       (cons 0 "ELLIPSE")
       (cons 41 0)
     (cons -4 "AND>")
(setq ellipsearcs
 (ssget "X"
   (list
     (cons -4 "<AND")
       (cons 0 "ELLIPSE")
       (cons -4 "<NOT")
         (cons 41 0)
       (cons -4 "NOT>")
     (cons -4 "AND>")
Share this post
Link to post
pBe
That is correct though
 (ssget "X" '((0 . "ELLIPSE") (41 . 0)))
would be enough for filter list
I was too engrossed with vlaobjects to think about a simple syntax with vanilla
Good stuff Ahankhah :)
Share this post
Link to post
Ahankhah
pBe,
thanks a lot.
everything you explain is very clear, unless you name pBe 8)
Share this post
Link to post
Lee Mac
(if
(= StartAngle 0)
(Open/EllipseArc)
Not quite.
Consider:
(entmakex
   (list
       (cons 0 "ELLIPSE")
       (cons 100 "AcDbEntity")
       (cons 100 "AcDbEllipse")
       (list 10 0.0 0.0 0.0)
       (list 11 1.0 0.0 0.0)
       (cons 40 0.5)
       (cons 41 0.0)
       (cons 42 pi)
(setq ellipses
(setq ellipsearcs
This won't work for the above counter example, consider the following instead:
(defun c:ellipses nil
   (sssetfirst nil
       (ssget "_X"
           (list
               (cons 0 "ELLIPSE")
               (cons 41 0.0)
               (cons 42 (* 2 pi))
(defun c:ellipsearcs nil
   (sssetfirst nil
       (ssget "_X"
           (list
               (cons 0 "ELLIPSE")
               (cons -4 "<OR")
                   (cons -4 "<>")
                   (cons 41 0.0)
                   (cons -4 "<>")
                   (cons 42 (* 2 pi))
               (cons -4 "OR>")
Share this post
Link to post
pBe
Not quite.
:lol: I realize that right after i posted.
Consider:
   ......                (cons 42 (* 2 pi)) ......
Really? Guess i ddnt do a thorough test :)
Thank you for the info.
Share this post
Link to post
Ahankhah
This won't work for the above counter example, consider the following instead...
Lee, I am surprised of your excellent look and observing all side effects of any code:o.
Again and again and again..., thank you very much:D.
Share this post
Link to post
Lee Mac
A side effect I suppose from studying a maths degree involving countless proofs...
You're welcome Ahankhah :)
Share this post
Link to post
