ssget "minsert"
Ahankhah
Hi all,
is it possible to filter selection set to contain only minserted blocks?
If so, how?
Thanks to anyone who spends her/his time to get any answer to the problem.
My approach .. :)
(defun c:TesT (/ ss i sset mins)
;;;=== Tharwat 24. Sep. 2011 ===;;;
 (if (setq ss (ssget "_x" '((0 . "INSERT"))))
       (setq sset (ssname ss (setq i (1- i))))
       (setq mins (vl-remove-if-not
                    (function (lambda (x)
                                (eq (car x) 100)
                    (entget sset)
       (if (not (member (cdr (cadr mins)) '("AcDbMInsertBlock")))
         (ssdel sset ss)
 (alert (strcat "Number of Minsert Blocks >> :"
                (itoa (sslength ss))
                "Nos."
Tharwat
Thank you Tharwat,
your code is very good, but isn't it possible to filter minserted objects just in one line like this?
(setq ss (ssget "_x" '((0 . "INSERT")(100 . "AcDbMInsertBlock"))))
I know it isn't correct, but someting like it...
Thank you Tharwat,
Actually that what I did try first but it did select all blocks without considering the filtration of minserts only at all .
If the 100 filter doesn't work ( which I think that it should ), then I think that you will have test all of row / col values:
(ssget "_X" '((0 . "INSERT")
             (-4 . "<OR")
               (-4 . ">")
                (44 . 0)
               (-4 . ">")
                (45 . 0)
               (-4 . ">")
                (70 . 0)
               (-4 . ">")
                (71 . 0)
             (-4 . "OR>")))
-David
             (-4 . "<OR")
               (-4 . ">")
                (44 . 0)
               (-4 . ">")
                (45 . 0)
               (-4 . ">")
                (70 . 0)
               (-4 . ">")
                (71 . 0)
             (-4 . "OR>")))
-David
David,
thank you very much for showing all possible differences between "entget"ing "INSERT"' and "MINSERT".
Edited by Ahankhah
