jlm Posted September 25, 2011 Share Posted September 25, 2011 am getting a "Failure to create CommCTRclientsink object!" error every time i start up and a few commands don't work from the keyboard until i do a pan or zoom fromt he drop down menu. the advice is to perform a repair from the install disk, but when I try that, i get an install message that says I need to enter a variety of data intot he command line, like the MS , etc, and i don't know what theya re looking for. this is using the orignal purchased disk also, what is the likelihood, if i re-install, that i will be kaput? i can still use the program as is, I cannot afford to not be running thx Quote Link to comment Share on other sites More sharing options...
Jack_O'neill Posted September 25, 2011 Share Posted September 25, 2011 Here is a link to what Autodesk has to say about it: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=8245068&linkID=9240617 According to that, a reinstall is your only hope. Quote Link to comment Share on other sites More sharing options...
ReMark Posted September 25, 2011 Share Posted September 25, 2011 If you first uninstall (cleanly) then reinstall I don't see where you should have a problem. I'd also find, download and install any updates or hot fixes (that apply) for AutoCAD 2006 prior to running the program for the first time after the re-install. Quote Link to comment Share on other sites More sharing options...
jlm Posted September 26, 2011 Author Share Posted September 26, 2011 thanks; will do a complete uninstall then a re-install jm Quote Link to comment Share on other sites More sharing options...
