Changing "Reference Name" to match xref file name
I have many drawings where the xref has been repathed, but xref manager pallate does not update the reference name. For example:
Reference Name = "Elevation"
but actual file name/found at path is "BN00-CT-TH001"
I want to change the reference name to match the filename, You can do this by typing over the reference name manually, but a lisp would be better as I have to change multiple xrefs in over 200 dwgs.
Any one help?
Something like this:
(vl-load-com)
(defun c:RenameXRefs (/ name)
 (vlax-for bo (vla-get-Blocks (vla-get-ActiveDocument (vlax-get-acad-object)))
   (if (= (vla-get-IsXref bo) :vlax-true)
       (setq name (vla-get-Path bo))
       (while (wcmatch name "*\\*")
         (setq name (substr name (+ (vl-string-search "\\" name) 2)))
       (while (wcmatch name "*.[dD][wW][gG]")
         (setq name (substr name 1 (- (strlen name) 4)))
       (vl-catch-all-apply 'vla-put-Name (list bo name))
Note though it doesn't update the manager's display immediately. But once you've re-opened the DWG it works fine. I'd advise running it through a script on multiple DWGs.
There's 2 possible problems though:
  1. You cannot rename nested xrefs. For those you need to open the DWG where it is a 1st level xref. And if there's nested together with 1st level, you could run into problems with those.
  2. It is possible that the same DWG file is loaded into 2 differently named XRefs. This will only rename the 1st, not merge the 2nd into the same XRef name.
Here's another version that I use. It has the ability to refresh the dwgs so it will show up right away, and the ability to repath to a new folder location if needed.
;      << Replace old xref files with a set of new xref files >>
;                     << By MH, June 2010 >>
;                           << Version 1.1 >>
;       NOTE: If new xrefs are in a different folder, you must enter new paths
;             in STEP 2 to run XrefPathChange routine from the code, otherwise
;             remove all code in STEP 2.
(defun c:xrefnamechange (/ b bcol path)
 (vl-load-com)
 (setq bcol (vla-get-blocks (vla-get-activedocument (vlax-get-acad-object))))
 (foreach blk '(
;>>>>>  STEP 1.                                           >>>>>>
;>>>>>         Enter all xref names below in this format  >>>>>>
;>>>>>         ("OldXrefName" . "NewXrefName")            >>>>>>
   ("SJS-E-TBLK-A0" . "SJS-E-TBLK-A0_NEW")
   ("SJS-E-LP0B" . "SJS-E-LP0B_NEW")
   (if
     (and
      (not (vl-catch-all-error-p (setq b (vl-catch-all-apply 'vla-item (list bcol (car blk))))))
      (= (vla-get-isxref b) :vlax-true)
      (progn (vla-put-name b (cdr blk))
         (if (= (setq path (vl-filename-directory (vla-get-path b))) "")
       (vla-put-path b (strcat (cdr blk) ".dwg"))
       (vla-put-path b (strcat path "\\" (cdr blk) ".dwg"))
       (vla-reload b)
;>>>   STEP 2.        >>>>
;>>>           If xref path is unchanged, add ; in front of each line of code   >>>>
;>>>           in this section to block the xrefpathchange command. Otherwise,  >>>>
;>>>           enter all xref paths to be changed in this format.               >>>>
;>>>  (xrefpathchange "c:\\Oldfolder\\oldfolder" "c:\\newfolder\\newfolder")    >>>>
(xrefpathchange "L:\\Buildings\\E01048\\E" "c:\\temp\\TEST\\XREF")
(xrefpathchange "L:\\Buildings\\E01048\\01\\BLK-E" "c:\\temp\\TEST\\XREF")
(XReload)
);end of c:XrefNameChange
;....        Xref Path Change sub routine             ......
(defun xrefpathchange (path1 path2 / newpath xrpath)
 (vl-load-com)
 (vlax-map-collection
   (function
     (lambda (x)
       (if (= (vla-get-isxref x) :vlax-true)
         (progn (setq xrpath (strcase (vlax-get x 'path) t)
                      path1  (strcase path1 t)
                      path2  (strcase path2 t)
                (if (and (vl-string-search path1 xrpath)
                         (setq newpath (vl-string-subst path2 path1 xrpath))
                         (findfile newpath)
                  (if (vl-catch-all-error-p (vl-catch-all-apply 'vla-put-path (list x newpath)))
                    (princ (strcat "\n**OLD path found but was not changed!\n" xrpath))
                    (princ (strcat "\n" newpath))
); end of XrefPathChange
;....          Xref Reload sub routine                 .......
(defun XReload (/ cObj cName); Updated 2007-10-1: added error trap
 (defun *error*(msg)
   (setvar "modemacro" ".")
   (setvar "cmdecho" 1)
   (princ "\n...Reload xref terminated!!!  ")
   ); end of *error*
 (setvar "modemacro" "Reloading loaded xrefs......please wait......")
 (setvar "cmdecho" 0)
 (setq cObj(tblnext "BLOCK" T))
 (while cObj
   (setq cName(cdr(assoc 2 cObj)))
   (if
     (and
    (=(logand(cdr(assoc 70 cObj))32)32)
    (=(logand(cdr(assoc 70 cObj))4)4)
    ); end and
      (vl-cmdf "_.xref" "_unload" cName)
      (vl-cmdf "_.xref" "_reload" cName)
      ); end progn
     ); wnd if
 (setq cObj(tblnext "BLOCK"))
 ); end while
 (prompt "\n--- Xref change finished! ---")
 ); end of XReload
Irne,
Unless I've overlooked something, couldn't this:
Become:
(vl-filename-base name)
Thanks yes, I can't remember what I was thinking when I wrote that lot. It couldn't've been to avoid vla, since it's used elsewhere. :o
Ah, the joys of Mac :roll:
  • 1 year later...
Actually, the new line of code needs to be:
(setq name (vl-filename-base name))
But I am a newbee to the world of lisp and VL, so it took me a while to figure that out.
I also combined the XReload into my version.
; RenameXRefs - renames xref name to match filename (base name)
(vl-load-com)
 (XReload)
;====  Xref Reload routine - Reloads XRef's after rename                      ====
 (defun *error*(msg)
   ); end of *error*
 (while cObj
   (if
     (and
    ); end and
      ); end progn
     ); wnd if
 ); end while
 ); end of XReload
Actually, your code could be shortened to:
(defun c:renamexrefs ( )
   (vlax-for b (vla-get-blocks (vla-get-activedocument (vlax-get-acad-object)))
       (if (= :vlax-true (vla-get-isxref b))
               (vl-catch-all-apply 'vla-put-name (list b (vl-filename-base (vla-get-path b))))
               (vla-reload b)
(vl-load-com) (princ)
  • 3 years later...
               (vla-reload b)
I receive the following error when running the above code. However, the code does work. Thanks.
; error: Automation Error. File access error
  • 7 years later...
Hi,
Is it possible to get the same lisp but able to rename the xref even if they are in different folder ?
Thnaks
