Copy an object along arched P-line
Hi forum! :)
I was wondering if there is an app which allows the user to copy an object along an arched P-line with a given offset and for the object to inherit the P-lines rotation? I know you can do something similar with the application NumInc which i found through this page (ty, I use it all the time! :D), but I cant seem to find something similar for the described use.
Thanks in advance!
Have you tried the command MEASURE, with the option of using a block.
Set up the block correctly, and you are on your way. :D
Thanks for the super quick reply! :) it worked like a charm ^^
