I'd go into the BHatch dialogue box and remove the big boundry and then add the small ones. That way it's still one hatch.
Trim only works with one of the small rectangles, not multiple.
It also seems that it would be easier to simply create one rectangle with hatch and copy-multiple
Id go with tiger's recommendation, it would take longer to copy multiple in each rectangle.
just hatchedit, use Add:select objects to select the small rectangles, then use Remove Boundaries on the large rectangle.
I will third that. You cant really do it much quicker unless its by the power of though. And, if its lunch time on Friday even that wont be as quick.
