Hi,
I am getting really annoyed with UCS FOLLOW. I turn it on and it works fine but it seems to always turn itself off somehow but i dont know why (maybe its when I leave a drawing and return? not sure) is there a way of making it stay on even after the drawing has been closed/re-opened?
Thanks
Dave
Thanks Mark,
I have tried saving it in a template but it still reverts back to being off, the other fix also refers to using it with viewports but I want to use it in model space.
I think UCSFOLLOW only applies to viewports and is viewport specific...
UCSFOLLOW applies when you create new UCS points in MODEL space from which you can display using a viewport. If you are creating sections through say a bridge structure you can create new UCS for each section. I have attached a drawing to explain this, use the toolbar UCS II to view different views and then try UCSFOLLOW 1, you may understand more then.
Thanks
UCS.dwg
...Ok, I looked it up and I was wrong...
UCSFOLLOW does apply in modelspace and is retained when the dwg is saved, closed and re-opened. Worked ok for me...
Could yours be set to return to 0 in your acad.lsp or some other setup file?
Yeah, thats what it probably is but I dont know where, thought some bright spark might know . . .
