[Help] I'm finding lisp copy from XZ plane to XY Plane
Hi all, please help me this problem.
My partner accidentally draw sth in a XZ plane, so i can't copy it to my XY plane drawing, and i don't want to split two drawing and send to my boss. I tried to search but no result, may be my English not good to use Google Search my idea. So i post my question here, please help me, one lisp, links or some advise will save my life now.
Thanks all
http://www.mediafire.com/?3c5qw5x7x939q19
How about W-Blocking your partners drawing, inserting it in on the correct plane, and then exploding it?
Hix, It didn't work :( It appeared exactly when i copy and paste. Or i going wrong some step ?
I am probaly missing something obvious although I don't see the problem from my quick inspection (doesn't help that I don't have the font necessary/can't read the annotation).
I think I did it right , see the attached drawing .
First explode the blocks to be able to see the changes .
command :ucs -> x 90
command :ucs -> y 90
command :plan
command mirror .
Hope it is correct ..
Tharwat
Tharwat.dwg
Hi, thank you Tharwat. You've wake me up. One thing seemed to be big problem (with me) has been solved with only ucs and mirror ^^ Thank you again, again... ^^
Hi, thank you Tharwat. You've wake me up. One thing seemed big problem (with me) has been solved with only ucs and mirror ^^ Thank you again, again... ^^
You're welcome buddy .
I am so glad for you . :D
Note: Why did not you uploaded your drawing to the forum and not to mediafire ?
Regards.
Regards.
oh, I just avoid make full limit of 4room' host ^^ . In my country, almost 4r are encouraged upping big file to free host, so it become members habits, hi ^^
