CRAZY-88 Posted October 15, 2008 Share Posted October 15, 2008 this question has probably been asked before, but hey no harm in asking again. I am using AutoCad2009, I need to do floor areas for a project that I have at the moment. I know how to use the area command and how to convert the info in to sq m & sq ft. What i would like to know is this, is there a lisp routine that will do it for me, as in if i click the polyline it will give me the info in text and place it in the area.? This would be a great help as I have lots of single areas that I need to put this information on. :? :? Quote Link to comment Share on other sites More sharing options...
mdbdesign Posted October 15, 2008 Share Posted October 15, 2008 Try this it is free: http://www.glamsen.se/CadTools.htm Quote Link to comment Share on other sites More sharing options...
GhostRider Posted October 15, 2008 Share Posted October 15, 2008 I use this from time to time... drawback is you have to click each corner instead of just once in the area.... ;;SQFT Area Lisp Program ;; ;;Revised : 10/16/07 (defun c:rar (/ P1 P2 P3 P4 P5 P6 A B C D E F PT PTLIST OS ss ssl wl ctr l1 l2 wn wlist llist vlist bn dlist dllist dvlist ) (setvar "CMDECHO" 0) (setq wl 0) (setq E 0) (setq D 0) (setq OS (getvar "OSMODE")) (setq l1 70) (setvar "OSMODE" 32) (while (/= nil (setq PT (getpoint "\nPick a room corner point, press return when done: _int " ) ) (progn (if PT (/= nil (setvar "lastpoint" PT)) ) (setq PTLIST (cons PT PTLIST)) ) ) ) (setq PTLIST (reverse PTLIST)) (setvar "OSMODE" 0) (command "PLINE") (while (/= nil (car PTLIST) (progn (command (car PTLIST)) (setq PTLIST (cdr PTLIST)) ) ) ) (command "AREA" "e" "l" "ERASE" "l" "") (setvar "OSMODE" OS) (command "redraw") (setq A (/ (getvar "area") 144)) (setq P1 (getpoint "\nPick center point of text: ")) (setq P2 (list (car P1) (- (cadr P1) 5))) (setq P3 (list (car P1) (- (cadr P2) 5))) (setq P4 (list (car P1) (- (cadr P3) 5))) (setq P5 (list (car P1) (- (cadr P4) 5))) (setq P6 (list (car P1) (- (cadr P5) 5))) (command "text" "c" P1 6 0 (strcat (rtos A 2 2) " SQFT.")) (setvar "cmdecho" 1) (princ) ) Quote Link to comment Share on other sites More sharing options...
tclaudiu Posted August 26, 2009 Share Posted August 26, 2009 Hello everybody! Is there any lisp or quick way to get the area from a closed polyline in to the clipboard memory? I want something like this: click on a polyline and then just the press paste in another application. Thank you in advance! P.S.: Sorry for wrong thread posting, i really need a little help here; I am using AutoCAD Civil 3D 2010 and I have more than 400 closed polylines and i have to check every single polyline area and correlate the value in Excel. I tried to use Civil tools, but its too complicated only for this task. Thanks! Quote Link to comment Share on other sites More sharing options...
sachindkini Posted August 26, 2009 Share Posted August 26, 2009 (defun c:CA (/ *error* p1 p5 p6 a b c d e fn) (setq oldCM (getvar "CMDECHO") oldos (getvar "OSMODE")) (defun *error* (msg) (if oldCM (setvar "CMDECHO" oldCM)) (if oldos (setvar "OSMODE" oldos)) (princ msg) (princ)) (setvar "CMDECHO" 0) (setvar "osmode" 524) (if (and (setq p1 (getpoint "\nSELECT PLINE FOR CAREPET AREA: ")) (setq p5 (getpoint "\nWHERE TO PLACE TEXT: "))) (progn (setq p5 (polar p5 pi 1250)) (setq p6 (polar p5 0 2500)) (setq fn (getstring t "\nFLAT NO.:")) (command "AREA" "E" P1) (SETQ A (GETVAR "AREA")) (SETQ F (SF)) (defun sf (/ sm sf st) (setq sm (getvar "area")) (setq sf (* sm 0.000010764)) (setq sf (rtos sf 2 2)) (SETQ ST (strcat sf " SQ. FT.")) (PRIN1 ST) ) (SETQ B (/ A 1000000)) (SETQ C (RTOS B 2 2)) (SETQ D "CARPET AREA OF FLAT") (setq e (strcat "NO. " FN " = " C " SQ.MT.")) (setq F (strcat " = " F)) (COMMAND "TEXT" "S" "STANDARD" "f" P5 p6 "275" D "text" "" e "text" "" f) ) (princ "\n>") ) (setvar "cmdecho" oldCM) (setvar "osmode" oldos) (princ) ) Quote Link to comment Share on other sites More sharing options...
wkplan Posted August 26, 2009 Share Posted August 26, 2009 Hi tclaudiu, mdbdesign's tools should cover this. There is a feature "Area calculation of polylines based on color or layer. Results can be exported to Excel" in there. I haven't tested his software, but I think it should do it. If you wish to correlate values in excel, you should have a identifying number. Maybee this will help: http://www.cadtutor.net/forum/showthread.php?t=22874 http://www.jefferypsanders.com/GA.lsp http://discussion.autodesk.com/forums/thread.jspa?messageID=1135957 regards Wolfgang Quote Link to comment Share on other sites More sharing options...
