Netminder Posted October 12, 2011 Posted October 12, 2011 Thanks for the help, and the humor, for my initial request now I need a follow up. I have drawn a sheet metal part and want to save and export it as a FLAT PATTERN, unfolded .iges or .step file. When I try to save the part in flat format I am only given the .dwg or .dxf capability. When I attempt to rename and save the sheet metal part as a flat pattern I get, “You cannot translate PartXX to this file format in flat pattern edit mode. Would you like to exit flat pattern edit mode and continue saving?” I am trying to get this pattern sent directly to our machine shop’s CNC so we skip the middle man and their redraw of my part. I know there must be a way to save and export this part as a flat pattern. Any suggestions from all of you machinist drafters? I've attempted to attach the file. We'll see if that works. Thanks. Part02b.ipt Quote
JD Mather Posted October 12, 2011 Posted October 12, 2011 Now this bugs an old machinst - you are not fully constraining your Sketch1. You might read this document http://home.pct.edu/~jmather/skillsusa%20university.pdf Quote
rdharvey Posted October 13, 2011 Posted October 13, 2011 Why can't they just work from your dxf? Quote
