amelia283 Posted October 13, 2011 Share Posted October 13, 2011 Hey all, I am running Civil 3D 2010. I have hatch a bunch of areas with the gravel pattern hatch. However, they are at different scales. When I try to change the scale I get a totally different hatch pattern. I have attached a screen shot showing my problem. Hatch picture.pdf Thanks! Quote Link to comment Share on other sites More sharing options...
designerstuart Posted October 13, 2011 Share Posted October 13, 2011 assuming the name of the hatch pattern does not change, i think this is an issue with a sort of 'exploding' of hatches - usually beyond the 1000000 square units from the origin. are these tiny hatches in a massive drawing? and are they a long way from the origin? i don't know a solution, but try resetting the drawing limits, copy entire drawing out into a fresh one, or move everything closer to the origin. Quote Link to comment Share on other sites More sharing options...
amelia283 Posted October 13, 2011 Author Share Posted October 13, 2011 The origin was the problem. When I open the hatch edit box there is a click to set new origin button. When I clicked in the middle of the hatch pattern I got the correct hatch back. Thanks! Quote Link to comment Share on other sites More sharing options...
BIGAL Posted October 14, 2011 Share Posted October 14, 2011 Gravel and concrete hatch both suffer from this origin problem often used in civil stuff you only need to pick a point somewhere near the object to be hatched. Quote Link to comment Share on other sites More sharing options...
