Browny_76 Posted October 17, 2011 Posted October 17, 2011 I have installed autocad 2012 and it seems that the TXT2MTXT command no longer works. Has anyone else had this problem? & is there a way to fix it?? Quote
Bill Tillman Posted October 18, 2011 Posted October 18, 2011 I have installed autocad 2012 and it seems that the TXT2MTXT command no longer works.Has anyone else had this problem? & is there a way to fix it?? I'm running 2012 and TXT2MTXT works fine here. What exactly do you mean when you say "no longer works." Quote
Browny_76 Posted October 18, 2011 Author Posted October 18, 2011 I'm running 2012 and TXT2MTXT works fine here. What exactly do you mean when you say "no longer works." I type in TXT2MTXT and it says "unknown command" Quote
Cad64 Posted October 18, 2011 Posted October 18, 2011 Did you install the Express Tools? The TXT2MTXT command is an Express Tool. Quote
