Repositioning via rotate - but not directly rotating
I'm trying to have some advanced positioning - I don't know if this can be done using dynamic blocks. Start with some basic geometry - let's say a triangle - /\. Now, I can add a rotate parameter & action that will let me spin that as I wish.
Next - add a couple attributes. I have a pair of attributes, separated by a text, aligned as "A1.A2" A1 is right-justified, and A2 is left-justified, so when edited they remain in the form "A1.A2" regardless of length. I can now add a point parameter, combined with a move action, that will let me reposition these three entities freely.
My question - can I have the rotate action trigger a move, such that the text repositions to a defined location without changing orientation (DON'T rotate the text!)?
So if I start with (leading . used for positioning in this forum text box):
. A1.A2
I want to rotate it to:
. A1.A2
While I'd love to have it totally self-adjust, I mainly need it to handle 45-degree increments of rotation.
Is there a way of expressing this using dynamic blocks using action and/or constraints? Or would this require a lisp construct?
