norm Posted October 25, 2011 Posted October 25, 2011 I am having trouble using wipeout with text. I want to place text over a lineand with text on top, but when i print the line that i wipedout has printed Quote
MSasu Posted October 25, 2011 Posted October 25, 2011 If I remember well, there were a lot of similar threads in the past regarding issues with Wipeout usage - may try a search on Forum to find similar problems / solutions (i.e. http://www.cadtutor.net/forum/showthread.php?32740-Wipeout-behind-text-over-hatch). Regards, Mircea Quote
SuperCAD Posted October 25, 2011 Posted October 25, 2011 Use background masking, or make a DWF first and then plot to your printer. I know that there is a problem in 2008 with printing wipeouts when plotting from AutoCAD to a plotter. If you make a DWF first, it should work. Quote
RobDraw Posted October 25, 2011 Posted October 25, 2011 Is it the frame of the wipeout that has printed or is it a black box? Quote
SLW210 Posted October 25, 2011 Posted October 25, 2011 Are you plotting from paperspace? Is your line in paperspace or model space? Is your wipeout in paper sapace or model space? What are your plot settings? Is plot paper space last checked or unchecked? Quote
ksperopoulos Posted December 21, 2011 Posted December 21, 2011 I am having a similar issue in AutoCAD 2012. I have masked text and wipeouts in model space that are over xrefs in model space. My viewport in paper space is set to a hidden shadeplot. This causes the wipeouts to not work correctly. Any ideas what I can do to use a hidden shadeplot AND have the wipeouts and text masking work? Quote
Organic Posted December 22, 2011 Posted December 22, 2011 I wouldn't use wipeouts at all, they are more trouble than they are worth. Quote
muqtar_cadpro Posted December 26, 2011 Posted December 26, 2011 Better way to put the text over the line or object is " Textmask " try this' Quote
ksperopoulos Posted December 28, 2011 Posted December 28, 2011 I can't when there are attributes related to the text inside one of my blocks. I do this though when I have just regular text. Quote
