CadFrank Posted October 25, 2011 Posted October 25, 2011 Hi, I would like to know if it is possible to create a hatch with the back ground color! if it is possible how can i do it! Quote
alanjt Posted October 25, 2011 Posted October 25, 2011 Use true color 255,255,255. It will show up white in cad (ugly), but plot how you want. Quote
CadFrank Posted October 25, 2011 Author Posted October 25, 2011 Well i want the color to hide the line of a block with another block by putting a back ground color in the area needed! Quote
CadFrank Posted October 25, 2011 Author Posted October 25, 2011 shouting? where !! not sure i understand it but it does work i just tried it! thank you very much this will increase my speed to draw some formwork ! cheers to that Quote
alanjt Posted October 25, 2011 Posted October 25, 2011 I'm referring to you ending every sentence with an exclamation point instead of a period. Enjoy. Shout (heh heh) if you need any help. Quote
CadFrank Posted October 25, 2011 Author Posted October 25, 2011 Well I just got another way of getting what I want.(!) the command wipeout puts a area in background color. and its faster then putting a hatch. cheers to that also Quote
alanjt Posted October 25, 2011 Posted October 25, 2011 Well I just got another way of getting what I want.(!) the command wipeout puts a area in background color. and its faster then putting a hatch. cheers to that also LoL, since you suggested a hatch, I just assumed you knew about Wipeouts and were trying to avoid the problems some encounter when creating PDFs.Glad you found something. Quote
CadFrank Posted October 25, 2011 Author Posted October 25, 2011 Oh! they might be some problems with pdf.. not to good for me but ill see if i get them. someone where i worked just suggested me that... ill see whats betters when i do a few test. thx alot again ! Quote
Jack_O'neill Posted October 25, 2011 Posted October 25, 2011 I have in the past been accused of not being the brightest crayon in the box, but i gotta ask....how does using a hatch the same color as your background help? Quote
Organic Posted October 26, 2011 Posted October 26, 2011 Colour 255,255,255 is the same color as white paper, so provided the OP is printing onto white paper, having a hatch that color will work exactly the same as an AutoCad wipeout without all the problems associated with wipeouts when printing. Oh! they might be some problems with pdf.. not to good for me but ill see if i get them. someone where i worked just suggested me that... ill see whats betters when i do a few test. 255,255,255 solid hatch has worked with every PDF program/printer I have ever used. The same cannot be said for wipeouts. Quote
