numberOCD Posted October 26, 2011 Posted October 26, 2011 Hey there, I'm have a long span of conduits in this tunnel and need to label each of the conduits its 3-4 digit assignment in each viewport of each page. I made a center line to each of these conduits in the layer named that 3-4 digit code (ex, Centerline of ET23 is in layer ET23). Does anybody know a way to make a leader that will just tell me the layer of the object (centerline) I attach it to? Or does anybody simple know a way to label the layer of an object? Thanks for the help! Quote
alanjt Posted October 26, 2011 Posted October 26, 2011 (defun c:Test (/ pt ss ent) (vl-load-com) (cond ((not (setq pt (getpoint "\nSpecify point on object: "))) nil) ((not (setq ss (ssget pt))) (alert "Point must be on object!")) (T (setq ent (entlast)) (vl-cmdf "_.mleader" "_non" pt PAUSE) (while (eq (logand 1 (getvar 'CMDACTIVE)) 1) (vl-cmdf "")) (if (not (equal ent (setq ent (entlast)))) (progn (vla-put-textstring (vlax-ename->vla-object ent) ;;(cdr (assoc 8 (entget (ssname ss 0)))) (strcat "%<\\AcObjProp Object(%<\\_ObjId " (if (vl-string-search "64" (getenv "PROCESSOR_ARCHITECTURE")) (vlax-invoke-method (vla-get-utility (cond (*AcadDoc*) ((setq *AcadDoc* (vla-get-activedocument (vlax-get-acad-object)))) ) ) 'GetObjectIdString (vlax-ename->vla-object (ssname ss 0)) :vlax-false ) (itoa (vla-get-objectid (vlax-ename->vla-object (ssname ss 0)))) ) ">%).Layer>%" ) ) (vla-regen *AcadDoc* acActiveViewport) ) ) ) ) (princ) ) Quote
numberOCD Posted October 26, 2011 Author Posted October 26, 2011 How do I use this code? Is it a LISP? And if so, What is the activation command? Thanks Quote
alanjt Posted October 26, 2011 Posted October 26, 2011 I assumed too much - sorry about that. It's a LISP routine. The syntax is just 'TEST'. Read this for loading: http://www.cadtutor.net/forum/showthread.php?1390-How-to-use-the-LISP-routines-in-this-archive Quote
numberOCD Posted October 26, 2011 Author Posted October 26, 2011 Thanks, works great. I know a bit about LISP Routines, but still not familiar with coding; so I couldn't quite identify the syntax. Thanks again for saving me hours! Quote
