John Welson Posted October 28, 2011 Posted October 28, 2011 Hi all.... I'm a self taught user of Autudesk Inventor 2012 and works in a the aluminium curtain wall industry. I've just started using Inventor for curtain wall manufacturing and encountered a problem with constraining hole position. I have a extruded hollow section with 2 bracket holes on the side. My design requires that these holes are positioned at a certain distance away from one end of the hollow. When I use iCopy, the length of the hollow will change according to the curtain wall module but I can't seem to constraint the bracket hole position which has to be at a certain distance away from one end of the hollow. Can anyone help me? Your guidance is very much appreciated. Lastlly, can someone tell me whether is there any online course or forum specializing in Inventor for curtain wall industry. Thanks very much John Welson Quote
JD Mather Posted October 28, 2011 Posted October 28, 2011 Sounds like an easy part - attach what you have so far. Quote
John Welson Posted October 28, 2011 Author Posted October 28, 2011 Hi JD....thanks for the quick reply. I'm having problems attaching the file. Can I email to you instead? Thanks John W Quote
John Welson Posted October 28, 2011 Author Posted October 28, 2011 Hi JD, I manage to attached the file using Winzip. Thanks in advance for your help. Stick iCopy Template.zip Quote
JD Mather Posted October 28, 2011 Posted October 28, 2011 An assembly (*.iam) without parts (*.ipt) is useless. An assembly file is simply a record of hyperlinks to ipt files and a list of assembly constraints. Note the tiny size of that file! Quote
John Welson Posted October 28, 2011 Author Posted October 28, 2011 Hi JD.... sorry about that. Thanks very much for your patience. I've attached all the part files including the assembly file. Thanks 1-3.zip 2-3.zip 3-3.zip Stick iCopy Template.zip Quote
John Welson Posted October 31, 2011 Author Posted October 31, 2011 Hi JD.... I managed to figure it out the problem why the bracket holes are not constraint in place. Anyway thanks. Quote
